Author Topic: ISP charges  (Read 3799 times)
ISP charges
« on: November 07, 2002, 22:26 »
I have an account with BTInternet which costs me £16 a month.  My wife has a separate BTInternet account which also costs £16 a month.  I'm now on ADSL which I think is costing approx £30 a month.  Both PCs are now networked using my account.
My questions are:
Can I now cancel my wife's account?
Is the ADSL charge over and above the normal £16 a month or will they just charge me the £30 ADSL fee?
Offline Mustapha Phagg
Re:ISP charges
« Reply #1 on: November 07, 2002, 22:41 »
Hi Clive: you can cancel both dial up accounts if you so wish and leave your ADSL active. Providing you and your better half don't want to use the net at the same time.
Or you can play safe and just cancel your own dialup account.
ADSL charge is completly seperate from your dialup account.
Happy surfing mate. ;D
Re:ISP charges
« Reply #2 on: November 07, 2002, 22:50 »
Thanks for that Mustapha.  I'll cancel them one at a time to play safe.  ;D  But since they are networked I can still use them both at the same time can't I?
Re:ISP charges
« Reply #3 on: November 07, 2002, 22:54 »
Afraid the networking side is over my head Clive, I can just about manage one pc.
Have to ask someone with more brains than me on that one.
Re:ISP charges
« Reply #4 on: November 07, 2002, 22:56 »
Well you have already saved me £16 a month!  I'll have to pay you commission.   ;D  ;D  ;D
Online Simon
Re:ISP charges
« Reply #5 on: November 07, 2002, 22:58 »
What I would suggest, Clive, is that you cancel the two dial up accounts, and then get two 'pay as you go' accounts for yourself and Mrs Down, so you can still access the Internet in an emergency should your ADSL connection be interrupted, but it won't cost you anything if it's not being used.   :)
Re:ISP charges
« Reply #6 on: November 07, 2002, 23:02 »
When, when, when, gimme, gimme. ;D ;D
Re:ISP charges
« Reply #7 on: November 07, 2002, 23:57 »
Didnt you say that St.Adept had got you a wireless router Clive?
As I understand it the router has the actual IP address and it doesnt allow your supplier to know how many computers are running on it  ;)
If so the only reason Mrs.Clive would need her own account would be so that her e-mail address would still be available and active.
I cancelled my V21 56K account montns ago but my address is still active although I dont use it now it still gets an occassional spam one on it
If she is happy to change it to one of yours then there is no need for any further accounts unless you expect to have problems with your ADSL service or the router  :-*
