Author Topic: BIOS Prob  (Read 788 times)
Offline BIG_J
BIOS Prob
« on: March 22, 2005, 19:12 »
last night i went to the bios screen to try and "beef" up my cpu, i had an option for "high performance" defaults, i selected that and went to reboot, however, it would not reboot, all i get is a black screen.  what can i do? :?:
ith all there is, there is nothing.  Nothingness plagues us everyday.  Everyday nothingness consumes all leaving the void which cannot be filled.  The void, that eternal darkness seeps out from the cracks and devours all the light leaving only nothingness to consume all.  Nothingness is everything
Online Simon
BIOS Prob
« Reply #1 on: March 22, 2005, 20:21 »
Can you get back into BIOS?  If so, reset it to fail safe defaults and hopefully that should solve things.
BIOS Prob
« Reply #2 on: March 22, 2005, 22:45 »
If you cant get it to go into the bios again, like Simon suggested, then switch the pc off and open the case up. Find the clear CMOS jumper and set it in the clear position for a few seconds then put it back to the normal setting.
This should reset the bios to the normal or failsafe defaults  :)
