Author Topic: Firefox 1.0.2 Update NOW  (Read 1880 times)
Offline Camstop
« Reply #1 on: March 25, 2005, 00:13 »
Thank Cammy for that link.
Should I uninstall existing version first.? :)
« Reply #2 on: March 25, 2005, 01:54 »
It should be mentioned that if you upgrade Firefox, most of your extensions and themes will stop working unless they are found to be compitable with the new version.  This is the only reason I dropped Firefox and reverted to Opera, as the latter has all the functions without the need for extensions.
Just something to sleep on before upgrading to the newer version.
« Reply #3 on: March 25, 2005, 09:50 »
In the Tools > Options > Advanced section, there is a facility to check for updates, which also checks for updates to plugins, extensions, etc.  I have just used that facility myself, to upgrade to 1.0.2, and it worked with no hassle at all.  There is an icon which appears in the top right corner of the screen, when updates are available.
« Reply #4 on: March 25, 2005, 13:59 »
I've seen that option, Simon, and very useful it is too.  The problem I have is that if I was reliant on a certain plug-in (the "Notes" plug-in being extremely useful) and it hadn't yet been updated to work with the new version of Firefox, then I would be well and truly stuffed until the author had caught up with the browser.
Come to think of it, I don't see why Mozilla don't officially adopt some of the better extensions and incorporate them directly into the browser?
« Reply #5 on: March 25, 2005, 22:53 »
I think the updates are backwards compatible, Dave.  I also have the Quick Note plugin, among others, and they all still work, following the upgrade to 1.0.2.   :)
I would also like to see a lot of these built in, but I suppose they like to think half the fun for the end user is customising the browsers to the way they like them.  What I would like is an automatic update feature, similar to Windows Update, that at least informs the user of available updates, with the option whether to install or not.
« Reply #6 on: March 27, 2005, 00:03 »
Quote from: "Simon"
Thanks Simon. Didn't realise I could update from options.  :)
Next question..........What are Quick note plugins? :?:
« Reply #7 on: March 27, 2005, 11:01 »
Quote from: "Lona"
A bit like Notepad, Lona - sort of 'post-it' notes.
http://extensionroom.mozdev.org/more-info/quicknote
« Reply #8 on: March 27, 2005, 16:09 »
Quote from: "Lona"
Its best to delete the older version
Ive tried both ways and seem to have less problems after deleting the old version first
« Reply #9 on: March 27, 2005, 16:13 »
Quote from: "davy51"
Quote from: "Lona"
Ive tried both ways and seem to have les problems in deleting the old version first
Yes, that's my experience too, davy.  In fact, I always uninstall all old versions of everything before updating/upgrading these days.  I find it much smoother.
« Reply #10 on: March 27, 2005, 17:52 »
Quote from: "chorleydave"
Quote from: "Lona"
If you install it without deleting the older model the older one stays in the forlder and seems to cause problems.
Ive seen a lot of complaints about problems.
And im not getting any of them
so i must be doing something right
« Reply #11 on: March 27, 2005, 17:58 »
I wouldn't usually disagree with the above re uninstalling old versions, however, as these 1.0.x releases are merely patches and updates, I don't think there's a need to uninstall previous versions first, in this case.  When they put out a full new version, i.e. 1.1, then I would uninstall first, but not for these little updates.  I have installed 1.0.1 and 1.0.2 over the top of installed versions and had no problems, and it also saves reinstalling all your plugins again (depending where you inistalled them in the first place).
« Reply #12 on: March 27, 2005, 18:05 »
I just updated it as you suggested Simon and so far don't seem to have a problem.  :)
I'm not going to bother with notes.
