Author Topic: Firefox bookmark folder  (Read 1208 times)
« on: April 09, 2005, 14:50 »
g'day everyone
To save me trawling through windows explorer, do any firefox users know where the firefox bookmarks folder lives and if there is a built in facility to back it up.  Thankee   :D
« Reply #1 on: April 09, 2005, 16:04 »
Hi Dave,
It's in here >> C:\Documents and Settings\[yourname]\Application Data\Mozilla\Firefox\Profiles\[xxxxxxxx]\Bookmarks
« Reply #2 on: April 09, 2005, 17:37 »
Thanks Simon, i knew you'd know  :D
« Reply #3 on: April 09, 2005, 18:15 »
I use this daveeb
http://mozbackup.jasnapaka.com/
 just place a shortcut icon on your desktop that way you can either backup your latest Firefox profile and or if you use the Thunderbird mail  client that also at the click of the icon.... They back up seperatlely, the advantage is [instead of everty time having to manually search for the folder Simon mentioned]  you can not only "backup" but also "restore" earlier save backups.
For instance I have three save backups of both Firefox and Thunderbird, on different dates.....it also works for those using the Mozzila all in one browser, like Simon
« Reply #4 on: April 09, 2005, 18:30 »
Have you ever tried restoring a backup made with that software, Tony?  I did once, and it wouldn't work, so I was pleased I had also made a manual backup.  It's the sort of thing one might not test, until such time as it's needed.   :|
« Reply #5 on: April 09, 2005, 19:22 »
Quote from: "Tony"
I use this daveeb
Thanks Tony, i'll give it a look  :wink:
« Reply #6 on: April 10, 2005, 01:28 »
Quote from: "Simon"
If my memory serves me well, I had trouble trying to restore my Mozilla email backups onto a new Thunderbird install, when I swapped over from the Mozilla browser to Firefox and the Thunderbird email client. I got around it by transplanting my email profile from Moz to Thunderbird [the browser backup was not a problem]
But once that was done it works every time......and besides daveeb is already on Firefox....and if he's using Thunderbird....any backups he makes using that little program will be carbon copies of his existing profile.
« Reply #7 on: April 10, 2005, 09:46 »
I think I may have been trying to migrate from one version of Moz, to the next, and the backup tool wouldn't restore.  Perhaps it's fine restoring to the same version.
« Reply #8 on: April 10, 2005, 10:38 »
Thats it Simon,
every time you do a new install the "profiles" folder  has a different file name such as "9eht674h.default" or "zk946crb.default"
So when trying to do a restore with that program, it cannot find the correct "profile" to restore to. But once you have transplanted  you existing "profile" into the newly installed Firefox version, your sorted, as it will then be able to restore correctly. Of course doing up grades to Firefox or Thunderbird  does not affect it as your "profile" folder file path does not alter.
So, though your right to back up your "profile" folder as a "fail safe" measure. Lets say, for those who wish to semi auto back up their email folder say on a weekly/daily basis to another hard drive or partition. And have a "restore" facility as well this program is handy.
