Author Topic: Power Calibration Error  (Read 1144 times)
« on: April 20, 2005, 22:52 »
When I try to write to my DVD+R/RW drive, I get the error message 'Power Calibration Error' and the drive seizes up.  Can anyone explain this, please?
Gill
« Reply #1 on: April 20, 2005, 23:00 »
Have you just started using a different make of DVD Gill ?
I have found this which may be the cause of your problem :
http://www.pioneeraus.com.au/computer/faqs/faq_22.html
« Reply #2 on: April 20, 2005, 23:19 »
You may find this helpfull too, Gill:
http://www.dvdplusvideo.com/dvdguide001.html
« Reply #3 on: April 21, 2005, 00:54 »
Thanks guys - very useful links.  I suspect the root of the problem is that the type of blank DVD+R I'm using is a cheap 'budget' one from www.BigPockets.co.uk.  I think they only cost about 21p each (I'm such a skinflint)!  I've never had problems with these discs before, but I've just browsed the website and it would appear that they are no longer available.
As a matter of interest, what cheap and reliable blank DVD+Rs do other members use?
Gill
« Reply #4 on: April 21, 2005, 01:19 »
The last ones I got were Datawrite Classic Grey Label 8x DVD - R from :
www.ebuyer.com
I think they worked out at around £7 inc vat and postage for 25 so they were a little dearer than yours but no failures yet  :)
