Author Topic: Much cheapness thread  (Read 4062 times)
« on: April 22, 2005, 15:37 »
Can't find the solution to this problem
When I try to open much cheapness threads my browser closes down.
I can access all the other threads no problems.
I have tried opening this thread with both browsers ie6 and Firefox and they both close down the minute I click on it.
« Reply #1 on: April 22, 2005, 15:43 »
Have you tried opening an earlier page in that thread instead of the latest page, then going to the latest from the numbers ?
« Reply #2 on: April 22, 2005, 15:58 »
As the subject is here now, I maybe have a reason to talk about it:
In fact, 'Much Cheapness" thread doesn't concern me at all. It doesn't concern much those who live out of the UK. So, in my case, though it's very important to some, I don't feel the need to open it at all.
I may suggest that it has its' own section (including categories, maybe), to be more useful to those who are concerned. And leave the section "Useful Sites" for other things.
Having many categories in it, may make it faster and easier to open.
What do you think?     :roll:
« Reply #3 on: April 22, 2005, 18:59 »
That is actually a very good idea Joudi.  Thanks for suggesting it.   :D
« Reply #4 on: April 22, 2005, 21:05 »
faster and easier yes... it will also make removing old items via prunning easier.
« Reply #5 on: April 22, 2005, 21:28 »
Yes, good idea - why not call it, 'Cammy's Canny Corner'?   :)
« Reply #6 on: April 22, 2005, 23:42 »
That's all very well but it doesn't answer my problem.
I have tried opening it from the first thread but still the same result. :cry:
« Reply #7 on: April 23, 2005, 00:54 »
lona,
i have tested it on various spec machines and every browser i can think of.. iincluding the awful IE and Konqueror. ummm. I am not sure what is occuring.
can you get to it via the last post feature? or does it only occur when you try to view the thread from the begin (i.e. clicking on it on the index page)?
« Reply #8 on: April 23, 2005, 01:15 »
Shes managed to get on by disable SP2s popup stopper Sam, although she said she tried it earlier and it didnt make any difference ?
Shes gone to bed now so will poss tell you more tomorrow  :?
« Reply #9 on: April 23, 2005, 09:43 »
Well, there are no pop ups on here, so I would guess that to be a coincidence, Sandra.  It might be worth her clearing her cache and cookies - that often helps.
« Reply #10 on: April 23, 2005, 12:47 »
yes everything on the site is driven by php and xhtml.. so anything we need a popup for we use the xhmtl for instead.. i.e. the private messages
« Reply #11 on: April 23, 2005, 15:53 »
Everything seems to be working now and the only reason I can think of is I downloaded firefox 1.3 and it was after installing that I got the problem.
It was unusual for it just to be on that particular thread though. :?
« Reply #12 on: April 23, 2005, 16:54 »
It used to happen on the old forum, Lona, when someone's avatar or sig refused to load, or even a remotely hosted smiley.  Clearing your cache and cookies sometimes helps.
