Author Topic: adding ram  (Read 1929 times)
Offline princeofdarkness
adding ram
« on: April 28, 2005, 23:35 »
hello..
i got my boradband and xbox live setup and its all working great(i got pipex) but now i have faster net i want to start pc gaming as well as xbox live..
i have
amd 2.4
80 gig hard drive
256mb radeon graphics card
but i only have 256mb ddr ram and it is recommened now that have at least 256mb ram and games can run quite slow(offline) on my pc and i think its my ram.. i want some more ram anyway but i was just wondering how to find the speed of my current ram because theres no point throwing it away when i can have 512 and 256
thanx in advance PoD
quot;Spirits damned to rot
Eyes of the dead
Broken glass reflections
Show your flesh eaten away
adding ram
« Reply #1 on: April 28, 2005, 23:41 »
Yes you may as well add to your current ram rather than discard it PoD  :)
Go here and click on  Scan My System :
http://www.crucial.com/uk/index.asp
adding ram
« Reply #2 on: April 28, 2005, 23:58 »
it didnt really say what speed it was but it recommended 184-pin DIMM DDR PC2700
does that mean thats what i need 512mb of 184-pin DIMM DDR PC2700???
i dont no anything about ram apart from its expensive for a kid  :roll:
PoD
Eyes of the dead
adding ram
« Reply #3 on: April 29, 2005, 01:13 »
It must just check the mobo PoD, I thought it said it identified your existing ram.
Looks like your mobo has a 333 FSB so 512mb of 184-pin DIMM DDR PC2700 would be correct  :)
adding ram
« Reply #4 on: May 12, 2005, 22:30 »
Hi, POD.
If you're a bit strapped for cash (and who isn't) you might want to have a look on Ebay.  I normally wouldn't touch Ebay with a barge pole, but I have bought some excellent memory from sellers on there at ridiculously cheap prices in the past.
If you see some, but you are wary, refer back and I'm sure somebody will have a look at the link.
