Author Topic: Simple HDD question.  (Read 1005 times)
Offline Scotty_CFC
« on: May 06, 2005, 12:29 »
Currently, i have 1 x 40gb drive. Now i want more space, would it be possible to just add another HDD in the floppys dives place? (ie Remove the floppy drive, and add another hdd)
I dont want to get a new HDD altogether because i dont have a windows CD to reinstall.
Windows XP
Celeron 1.8
512mb ram
« Reply #1 on: May 06, 2005, 13:37 »
Yes you can fit one in place of the floppy but usually you will find that there is a space for an extra hard drive next to the one thats already fitted.
You can also get adaptors to fit a 3.5 inch drive in a 5.25 bay and replace a CD/DVD drive with a hard drive or a second floppy if desired.
The only limitation really is that unless you have a RAID mobo or an extra PCI Controller card you can only have a maximum of 4 IDE drives as you can only fit two drives, one as a master and one as a slave, to each of the primary and secondary IDE channels  :)
Offline Scotty_CFC
« Reply #2 on: May 06, 2005, 13:51 »
Nice one, thanks.
All i need is a cheap HDD off ebay :)
« Reply #3 on: May 06, 2005, 20:32 »
Quote from: "Scotty_CFC"
Nice one, thanks.
Take care, Scotty, you never know what might be hidden on a used hard drive.  :|
Offline PhilTheFish
« Reply #4 on: May 06, 2005, 20:58 »
Yeah....totally agree....don't buy one from anyone with a user ID such as GaryGlitteruk   :laugh:
« Reply #5 on: May 06, 2005, 22:07 »
It doesn't bear thinking about, does it?  How awful would that be, if it came to having to prove that stuff found on a used hard drive, wasn't put there by you?  Personally, I would never risk buying a second hand drive.  They are not all that expensive to buy new, from the likes of Dabs and Ebuyer.
