Author Topic: LogIn "Windows XP" automatically (directly)  (Read 1176 times)
« on: May 13, 2005, 14:36 »
Are you bothered by clicking on your account (session) icon every time you start your computer?
Well, here's one possibility to avoid passing through that process:
Go to «  START » menu and write « Control UserPasswords2 »
A dialog box called « Users account» will open, which has an option (?Users must enter user name and Password for this computer?), to be checked / unchecked in the ?Users? tab.
  It must be unchecked.
After clicking ?Apply?, it?ll propose you to select which account you do like to be logged in automatically in the future. (If you don?t usually use a password; don?t add here a password).
That will do the job.
But in fact, every time in the future, at the start of Windows, it?ll display for two or three seconds the message ?Changing of your parameters (settings)?, and it opens automatically; the account (session) of Windows which you have selected.
