Author Topic: pipex broadband  (Read 1849 times)
Offline princeofdarkness
pipex broadband
« on: May 15, 2005, 18:35 »
i got pipex after simon recommended it and i am to impressed so far.. i have done speed tests and once it was running at 0.2 mb and every time i am on xbox live and i am the host.. the whole game lags and it is rare i play a game that doesnt lag and none of my friends have that problem and they pay less for there broadband.. i have done all the tweaks available and there is not much of an improvement and i cant cancel coz if you cancel in the first year it costs 60 quid!!!
is there anything i can do to improve my speed.. baring in mind i have done most tweaks.. i have pipex 1mb and i use a wireless router
p.s my mums computer is on wireless donwstairs and it is runnin at 1.6mb
what shall i do  :?
Jonah(PoD)
quot;Spirits damned to rot
Eyes of the dead
Broken glass reflections
Show your flesh eaten away
Online Simon
pipex broadband
« Reply #1 on: May 15, 2005, 19:12 »
Your best bet is probably to contact support@dsl.pipex.com, and explain your situation, but check back here later, in case someone has an idea.  To be honest, I don't really understand your question!
Oh, just thought of something - which Pipex service are you using?  If you are you using one of the Lite services, there are limitations with those.
pipex broadband
« Reply #2 on: May 15, 2005, 20:21 »
Sorry !  I'm not here to add an answer, but a little remark:
How come that this post is viewed more than 130 times till now, in just about two hours?     :scratchit:
Normally, our forum was almost comletely empty of members and visitors today.  Where did that number of "Views" come from?
pipex broadband
« Reply #3 on: May 15, 2005, 21:19 »
Well spotted Joudi!  That's very intruiging.  I can only suggest that it might be a plague of searchengine webcrawlers (bots) but that number seems very excessive so I'm probably wrong.  Maybe Sam can shed some light on it?
pipex broadband
« Reply #4 on: May 15, 2005, 21:38 »
i dont know whats going on now.. xbox live disconnects like every 10 mins..
i have unlimited broadband thats all i know simon..
and the views thing is my fault.. i realized that pressing refresh counts as an extra viewand found it quite entertaining... sorry  :whistle:
Eyes of the dead
pipex broadband
« Reply #5 on: May 15, 2005, 21:52 »
Are you by any chance using a Linksys router POD?
pipex broadband
« Reply #6 on: May 15, 2005, 22:10 »
its a sum vision wireless-g adsl router
y??? btw xbox live is now disconnecting on every game i go on
Eyes of the dead
pipex broadband
« Reply #7 on: May 15, 2005, 23:11 »
It's just that a lot of people have had xbox live disconnecton problems with linksys routers and the answer was to downgrade the firmware.
The xbox live website says that the following routers are suitable to use with it...
http://www.xbox.com/en-IE/live/start/connect/faq/routers.htm
Incidentally, are you using any additional firewalls to the one provided by the router?
pipex broadband
« Reply #8 on: May 15, 2005, 23:13 »
i am using mcafee pro firewall and antivirus
Eyes of the dead
pipex broadband
« Reply #9 on: May 15, 2005, 23:22 »
I would try disabling McAfee firewall because your inbuilt router firewall will be much better anyway.  Obviously make sure your router firewall is  switched on and check it out using Shields Up.  There isn't much point in having two firewalls as that could cause endless problems.
pipex broadband
« Reply #10 on: May 16, 2005, 16:46 »
major problem.. i think.. i scanned my registrys with a registry cleaner and it says in one of them there is 242 errors and there a loads in other folders.. but it wont let me clean moire than 2 erros because its a trial... what should i do???
Eyes of the dead
pipex broadband
« Reply #11 on: May 16, 2005, 18:36 »
What should you do?  Chill out - that's what!   8)   Those registry cleaners will always find hundreds of faults even on a brand new installation of Windows.  It's extremely unlikely that your x-box problem is linked to a registry fault.
pipex broadband
« Reply #12 on: May 20, 2005, 15:52 »
i contacted pipex through email and they started going on about viruses but i know i havent got any n just didn listen to the rubbish they were talking and then i did a speed test.. and funnily enough after complainin my speed went form 0.3 to 0.9 and hasnt dropped since my complaint ... supicious?
Eyes of the dead
pipex broadband
« Reply #13 on: May 20, 2005, 16:12 »
a good moan normally gets you sorted!
pipex broadband
« Reply #14 on: May 21, 2005, 15:56 »
Quote from: "princeofdarkness"
Same here Pod, I was doing a lot of downloading and got disconnected. When I tried to reconnect I got error 721 (isp not responding)
I phoned techinical support and after 3 phonecalls, (the first 2 kept me hanging on for 10 minutes and then said "Too busy ring back tomorrow")
Just like you I got a load of rubbish told to me as well but after hanging up the phone I connected immediately.
Pipex is not the same since taking on all those freeloaders  :laugh:  :laugh:  :laugh:
