Author Topic: Skype  (Read 4830 times)
Skype
« on: May 22, 2005, 00:53 »
After watching the money programme on BBC2 last night about VOIP calls via Skype and other methods I decided to download Skype and give it a try.
I had heard about it a year or two back but never bothered with it.
Anyway I downloaded and installed it last night and got Lona and John (Suffolk 2000) to do the same and one to one it is amazingly clear but it wasnt as good in a 3 way chat.
Its much clearer than voice over msn messenger and has the advantage of conference calling of up to 4 people at the same time along with written messaging and file sharing all for free  :D
I emailed a few people about it and got a call just as I was about to go out this evening off some weirdo who lives near Skipton, (Hi Tony  :wub: ), seeing as hes notoriously tight he thinks its great even though he gets his phone calls for only 2p each now anyway :roll:
Apparently Simon is on it too but he has kept it to himself unless he has only just started using it  :wink:
Anyway if anyone fancies free phone calls anywhere in the world from pc to pc all you need is a microphone and speakers and 33kb or faster internet connection, think you need windows 2K or XP too, then have a look on :
www.skype.com
You can even buy a proper USB phone handset to use with it if you prefer from around a tenner upwards  :)
Skype
« Reply #1 on: May 22, 2005, 02:53 »
My views on skype are fine if you want to talk to more than one person and have a discussion with up to 4 people but on a one to one I would rather pay the 2p and talk on the phone.
I suppose it has it's uses for contacting folks around the world.  It's early days yet and I have only used it once so I will report back when I have used it over a longer period. :)
Skype
« Reply #2 on: May 22, 2005, 08:23 »
Quote from: "Sandra"
Apparently Simon is on it too but he has kept it to himself unless he has only just started using it  ;)
Skype
« Reply #3 on: May 22, 2005, 09:22 »
It was probably me Sandra.  I don't use it myself but Mrs Clive uses it all the time to speak to her colleagues since she works from home.  Usually they are 1 to 1 converstations but sometimes it's a conference with several people.
Skype
« Reply #4 on: May 22, 2005, 12:00 »
Quote from: "Simon"
It scanned my address book and put you down as an existing user Simon  :?
I must have another Simon XXXX in my address book  :?
Ooooh thats a really scary thought isnt it, two or possibly more Simons, maybe hes had himself cloned  :shock:
Re: Skype
« Reply #5 on: May 22, 2005, 13:23 »
Miss Jones, you say the nicest things  :kiss:  :kiss:  :kiss:
Skype
« Reply #6 on: May 22, 2005, 14:10 »
Quote from: "Simon"
Not me!  I use (funnily enough) Adept Telecom (maybe that's where he went!), which used to be Eurobell.
Skype
« Reply #7 on: May 24, 2005, 01:38 »
Srangely enough Joudi says he mentioned it over a year ago, I cant see his post but it appears that DJ did too as I have found this :
http://pc-pals.com/phpBB2/viewtopic.php?t=10438
I did say that I had heard of it ages ago but not tried it  :(
Skype
« Reply #8 on: May 24, 2005, 02:56 »
At that time I was wondering where to put it Sandra. I hesitated between this section "Software suggestion" and "Tech News", (or even "Useful sites and other places"). If my memory is good (unfortunately that's not always the case    :laugh:  ) I have put it in "Tech News". But not sure!
Skype
« Reply #9 on: May 24, 2005, 03:22 »
Here it is. I got it:
http://pc-pals.com/phpBB2/viewtopic.php?t=12908
I'm still wondering, why the "Search" option didn't catch it?    :roll:
Skype
« Reply #10 on: May 24, 2005, 07:58 »
Quote from: "joudi"
I've yet to come across a forum where the "Search" feature actually works, Joudi!  :|
Skype
« Reply #11 on: May 24, 2005, 08:28 »
We mustn't forget that we have had a massive cull of old posts too.  Theoretically they should only be non-technical ones.
Skype
« Reply #12 on: May 24, 2005, 12:22 »
and the conversion between the software might well have cause errors.
Skype
« Reply #13 on: May 24, 2005, 16:26 »
It never worked before, Sam.
Skype
« Reply #14 on: May 24, 2005, 19:15 »
hehe, well i also have never come across a search on a forum that works well!
it might even be better to use this
This is the google search engine with pc-pals as the site to search - it does bring up some odd items. probably as bad as the internal search engine :-)
