Author Topic: Log In Problems  (Read 21077 times)
Log In Problems
« Reply #15 on: June 04, 2005, 00:58 »
surely you have to type your password in somewhere? did you clear all the cookies etc and follow the pasword reactivation procedure?
Log In Problems
« Reply #16 on: June 04, 2005, 01:16 »
yes I cleared all cookies and still could only logon using memberlist but got it sorted when Sandra changed my password.
Can logon now using password.
Log In Problems
« Reply #17 on: June 04, 2005, 01:17 »
thats rather odd...memberlist just does exactly the same when you are login in, only thing i can think off is your browser saved the code for that page alone.
Log In Problems
« Reply #18 on: June 04, 2005, 01:18 »
eitherway you are in now...
Offline Michelle
    • Techieminx
Log In Problems
« Reply #19 on: June 04, 2005, 12:32 »
me too the first time - i had to reset my password
i just thought I'd forgotten it - and it hadn't remembered me as I'd done the reinstall  :laugh:
Log In Problems
« Reply #20 on: June 04, 2005, 12:34 »
it seems as if everyone can eventually get in, sorry about the inconvenience to you all.
Offline Dogsbody
Log In Problems
« Reply #21 on: June 04, 2005, 17:43 »
Quote from: "Lona"
Cunning plan didn't work then Sam  :laugh:
Log In Problems
« Reply #22 on: June 04, 2005, 17:56 »
what to block her??  :twisted:
Offline Dogsbody
Log In Problems
« Reply #23 on: June 04, 2005, 19:10 »
Quote from: "sam"
Correct in ONE  :)
Log In Problems
« Reply #24 on: June 04, 2005, 19:51 »
i will have to try again.. there has to be a way! :-)
Log In Problems
« Reply #25 on: June 07, 2005, 23:03 »
it looks like the view posts since last visit isnt working or it wont work for me
Log In Problems
« Reply #26 on: June 07, 2005, 23:13 »
Hi Davy,
A few people have had this problem.  One solution has been to clear your browser cache and cookies, and allow the site to set and store a new cookie.  Let us know if that works, or not.
Log In Problems
« Reply #27 on: June 08, 2005, 01:28 »
Quote from: "Simon"
Hi Davy,
I cleared everything and it still shows not new posts
i always have bad luck lol
Log In Problems
« Reply #28 on: June 08, 2005, 01:38 »
do you see any yellow icons on the main index page that would indicate that there are new posts in a particular forum. do you manage to login first time or does it take more that one attempt?
Log In Problems
« Reply #29 on: June 08, 2005, 01:47 »
Quote from: "sam"
I can log on just fine
no icons that i can see
but im using opera 8 so it might not show
update I logged on and off about 4 times and it worked
strange
