Author Topic: changing pixals and colours , help please  (Read 1178 times)
Offline Neelloc
« on: June 03, 2005, 11:35 »
:blush:
can anyone please tell me how to change to higher resolutionswith my pixals and also colour?
I am using windows ME .
I am still learning how to use a PC , not easy when you are getting older :)
Offline Camstop
« Reply #1 on: June 03, 2005, 12:02 »
Hiya Neelloc and  :welcome:
If you goto...
Control panel then Display then click the settings tab and you can adjust your screen resolution by dragging the pointer.
You can also stretch your screen dimensions by using the buttons on your monitor if that's what you meant .
Hope that helps   :thumb:
« Reply #2 on: June 03, 2005, 13:27 »
If it wont allow you to increase the colour and the screen resolution (pixel size) then the drivers for the graphics card may not be installed or may need updating, let us know if you can adjust them or not please  :)
A quicker way to get to the display settings is to right click on a blank part of your desktop and then left click on properties, this will open the Display Properties window, then left click on the Settings tab at the top right  :)
Offline Neelloc
« Reply #3 on: June 03, 2005, 21:09 »
:) Hi there. thanks for the help, have changed pixels etc;but now can't  :roll: manage to get a full screen on monitor so please what buttons do I use to stretch this many thanks. :roll:
« Reply #4 on: June 03, 2005, 21:19 »
There should be buttons on the front of your monitor, with various settings to stretch, centre, change brightness & contrast, etc, but usually, you shouldn't need to change these.  Can I ask why you wanted to change the screen resolution in the first place?
Offline Neelloc
« Reply #5 on: June 03, 2005, 21:46 »
Thanks wanted to change pixels for grandson ,as was given a game for his 11th birtday ,but unable to play it as not enough pixels  etc; :roll:
« Reply #6 on: June 03, 2005, 22:00 »
If you only want to change the screen resolution for the game, you might not want to adjust the monitor settings too much, or it will all need resetting when you change back to your usual screen resolution, unless, of course, you are going to leave it as it is set for the game.  When you play the game, it should fit the screen OK.
