Author Topic: Text Size In Posts  (Read 5258 times)
Text Size In Posts
« on: June 10, 2005, 22:23 »
Just a quickie - is everyone happy with the text size in posts on here?  As you may have noticed, it's a bit smaller than on the old forum, and I just wondered if anyone was struggling, particularly those using higher resolutions.
This is how it was on the old forum.
Offline Dogsbody
Re: Text Size In Posts
« Reply #1 on: June 10, 2005, 22:34 »
Quote from: "Simon"
Fine for me, but then again just had new varifocals :laugh:
DB
Offline Camstop
Text Size In Posts
« Reply #2 on: June 10, 2005, 22:51 »
Personally i'd say it's a little small and find it difficult when doing up url's and stuff.  :roll:
But i can live with it and wouldn't of complained if it wasn't brought up  8)  :laugh:
Text Size In Posts
« Reply #3 on: June 10, 2005, 23:07 »
Quote from: "Camstop"
Are we talking about the same things, Cammy?  I'm referring to the text you are reading right now, not what you type to get it.  :|
As for posting urls, that will hopefully be made easier, as I have found a mod which I am hoping Sam will install soon.  :)
Text Size In Posts
« Reply #4 on: June 10, 2005, 23:27 »
The bigger one is better for me Simon and I should think for anyone else above 800 x600  :)
Text Size In Posts
« Reply #5 on: June 11, 2005, 00:05 »
OK, I've changed it, but it can always be reverted if there are any complaints.  Sam is going to have a fit now - I've messed with the system files!  :horror:  :grin:
Text Size In Posts
« Reply #6 on: June 11, 2005, 00:18 »
I'm happier with the slightly larger size, too.  You've done a good thing, Simon.
Gill
Text Size In Posts
« Reply #7 on: June 11, 2005, 00:31 »
Yes thats fine now Simon  :)
Text Size In Posts
« Reply #8 on: June 11, 2005, 00:40 »
I just go to View, text size, increase and find a size I like.  :D
Text Size In Posts
« Reply #9 on: June 11, 2005, 09:23 »
Quote from: "Lona"
Well, perhaps you don't need to now.  :)  I know older people sometimes have difficulty with small text.  See, I like to consider everyone's needs on this forum...  :halo:
Is this OK, Lona?  :wahh:  :grin:  :scoot:
Offline Camstop
Text Size In Posts
« Reply #10 on: June 11, 2005, 09:31 »
Quote from: "Simon"
Yup i was thinking of the "reply" box text being too small and my prompt covers the last thing typed on times but the posts are fine  :D
Text Size In Posts
« Reply #11 on: June 11, 2005, 10:51 »
OK, that's slightly increased now as well, Cammy, but as I said, inputting of urls will be easier when we get the mod installed.  :)
Text Size In Posts
« Reply #12 on: June 11, 2005, 10:56 »
excellent, saved me a job...god my hangover is painful! :-) - thus explaining why i wasnt able to take part in this discussion! I'd agree though
Text Size In Posts
« Reply #13 on: June 11, 2005, 11:07 »
What you need, Sam, is a good fry up and a gallon of Lucozade.  :grin:
Text Size In Posts
« Reply #14 on: June 11, 2005, 12:03 »
Irn Bru is quite good if you can't get hold of Lucozade.  :laugh:
