Author Topic: password trouble  (Read 1259 times)
password trouble
« on: June 16, 2005, 03:40 »
One of the computers on my network has two user accounts
on one account the password has changed
on the other user account which did not have a password the computer has added a password
I have tried going in through safemode
but i cant get past the passwords at the welcome screen
Im thinking it has been hacked
but not sure cant get in to check anything
any suggestions would be apreciated
password trouble
« Reply #1 on: June 16, 2005, 11:41 »
I came across this program the other day but havent heard of anyone that has actually used it so I dont know how complicated it is to use or how effective itis.
Unfortunately it is rather expensive  :(
http://www.lostpassword.com/windows-xp-2000-nt.htm
password trouble
« Reply #2 on: June 16, 2005, 13:39 »
Quote from: "Sandra"
thanks Sandra but i think ill just reinstall windows
at $195 for this program its cheaper to install windows and lose some unimportant information
Thank you for the info though
password trouble
« Reply #3 on: June 16, 2005, 14:35 »
Rather than reinstall windows Dave, could you not just delete the user accounts and create new ones.
I had other 2 user accounts on my pc and deleted them without having to re-install windows.
password trouble
« Reply #4 on: June 16, 2005, 14:51 »
He cant get into either safe mode or normal windows to do that Lona  :(
I have just found this program which looks quite good and a lot cheaper than the other one I mentioned.
It seems that you can make a bootable floppy or cd  and just change it from in a DOS application  :)
http://www.password-changer.com/
password trouble
« Reply #5 on: June 16, 2005, 16:34 »
thank you sandra ill try this one and see if it works
