Author Topic: Phone cutoff  (Read 5295 times)
Re:Phone cutoff
« Reply #15 on: January 31, 2003, 13:37 »
When your phone is in the base/recharger Barra does it have a plug in connector like the mobile phone chargers do or is it just resting against spring loaded contacts?
I have a rechargeable torch that disconnects the batteries from the circuit when the charger is plugged in and the switch wasnt reconnecting when it was removed from the charger.Could it be a similar problem with your phone  ???
Offline Barra
Re:Phone cutoff
« Reply #16 on: January 31, 2003, 18:13 »
I actually have both, and both give the same result ie, nothing. I'm afraid it's a visit to argos in the near future :(
Re:Phone cutoff
« Reply #17 on: January 31, 2003, 18:29 »
Here's another idea. Take your phone to a friend's house. See if it works on their sockets. Could be something wrong with your sockets. :)
Re:Phone cutoff
« Reply #18 on: January 31, 2003, 18:32 »
Here's another suggestion. Take your phone to a friend's house and try their socket. Could be a faulty socket. Otherwise don't go past here for buying phones. I have bought from them many times and they are a good company. :)
www.telephonesonline.co.uk
Offline Barra
Re:Phone cutoff
« Reply #19 on: January 31, 2003, 19:06 »
Cheers Lona. I'll take a look. Sockets must be ok otherwise other phones wouldn't work in them
