Author Topic: Getting Outlook to display pictures sent in emails  (Read 786 times)
Offline BlueDevRoo
  • New Registration
Hi,
I used to use Outlook Express and when an email was received with pictures, you could view them.
Now I am using Outlook 2002 and I have to save the received pictures and then open them in a separate program.
Does anybody know if I can set Outlook up to display the pictures (jpg's etc)
Thanks,
Jez
« Reply #1 on: June 27, 2005, 08:01 »
Hi Jez, and  :welcome:
I think you need to go to Tools > Options > Security, then click the button 'Change Automatic Download Settings'.  You will probably find a box ticked to block images from being downloaded.  Untick it, and it should then allow images.
