Author Topic: Google Earth is out  (Read 1288 times)
Google Earth is out
« on: June 28, 2005, 23:00 »
And it's free! It's only for Windows (at least, for now) and it allows you to traverse the Earth using satellite imagery.  Type your post code and zoom in....
http://earth.google.com/
Google Earth is out
« Reply #1 on: June 28, 2005, 23:13 »
I can't seem to download it.  I just keep getting a 0 bytes file.    :?
Google Earth is out
« Reply #2 on: June 28, 2005, 23:20 »
...more software from google... they will be giving us o/s soon....I bet you microsoft are s**tting themselves
Google Earth is out
« Reply #3 on: June 28, 2005, 23:34 »
The resolution leaves much to be desired and is nowhere near as good as an aerial photo.
Offline Camstop
Google Earth is out
« Reply #4 on: June 28, 2005, 23:48 »
It works far better on places in the USA Clive and i can clearly see the rooms i stayed at in Florida the two times i've been  :D
On the down side they got rid of the Tennis courts about 2 years ago and they are still on the picture  :roll:  but it just looks the same picture as the last one of these that was posted.
Google Earth is out
« Reply #5 on: June 29, 2005, 00:08 »
A great site (program) Clive !
I'm able to find on it our street here. Yes, even the building where I'm staying in.
It's wonderful !!!      :)
Google Earth is out
« Reply #6 on: June 30, 2005, 12:08 »
I'm finding Google Maps an increasingly useful tool.  Check out its route-planning capabilities!
