February 01, 2026, 16:38
Technical Help & Discussion
TV picture and sound sync
Topic: TV picture and sound sync (Read 3775 times)
January 26, 2003, 23:02 »
I notice whilst watching some channels on my new TV that sometimes the picture and sound are slightly out of sync. Watching the same programme on another TV it is perfectly OK. Why should this be?
Re:TV picture and sound sync
January 26, 2003, 23:12 »
Satellite delay?
No, seriously, I have no idea, but there is a setting on my amp to increase or reduce delay, by so many milliseconds, which is supposed to optimise the sound to the size of the room, somehow. I have all mine set on 0. Is there such a setting on your Set Top Box, Clive?
Sandra
Ultimate Member
January 26, 2003, 23:13 »
Its Japanese Clive they often get them out of sync dont you remember the Bruce Lee films
Is it through your digital box Clive? It often happens on mine for some reason I think its possibly weather related as some days are beter than others
January 26, 2003, 23:16 »
Damn, that means I'll have to read the instruction book!
I noticed that Scrumpy Jack was online and hoped he might have seen my post.
January 26, 2003, 23:21 »
Yes it is through my digital box but so are all the other TV sets in the house. I haven't noticed it before on any other set, just this new one. The problem is that the new set is just a monitor and all the other equipment (satellite, VCR and DVD) goes through a "media station" before it gets to the screen. Without the media station it would have no sound at all.
Sandra
Ultimate Member
January 26, 2003, 23:25 »
He wont be much help in this digital age Clive
Now if you are having problems with an old Baird original TV he'll sort you out no problem
Sandra
Ultimate Member
January 26, 2003, 23:28 »
It looks like a setting in the TV sound menu Clive I should think.
As Simon said there are often adjustments for the delay to various speakers.
I can alter the delay to my surround ones depending on the size of the room
January 26, 2003, 23:32 »
OK, I'll have to call up the menu screen and have a play around. At least you have pointed me in the right direction.
January 26, 2003, 23:35 »
Yes, it definitely sounds like the Media Station may have delay options Clive. Set them all to the minimum, and that should solve your problem.
Reply #9 on:
January 27, 2003, 16:10 »
I checked the menu and there was a 20ms delay so I've set it to zero as you suggested. So far so good!
Reply #10 on:
January 27, 2003, 16:21 »
Hope it works Clive!
Apart from the sound issue, how are you finding the new TV? Is it all you expected?
Reply #11 on:
January 27, 2003, 16:33 »
I'm very pleased with it Simon. You have to have a good signal for plasma sets and it's best to pick it up via the sky box rather than the aerial. I have also been pleasantly surprised that people don't look squashed in the way that they do on some other wide screen sets I've viewed. Mrs Clive is absolutely delighted with it and the next step is to get a speaker system. We are going to the cinema tonight to see Chicago so I'm sure that will give me the impetus to get something sorted out.
Edit: change of plan, cinema tomorrow instead.
Reply #12 on:
January 27, 2003, 16:37 »
Ah, now, the reason people don't look squashed is that Digital broadcasts are true Widescreen (16:9), whereas terrestrial broadcasts are usually a hybrid widescreen (14:9), in order that people with 'square' TVs don't get large black borders.
Reply #13 on:
January 27, 2003, 16:58 »
In that case, viewing through the digibox is mandatory - something I wasn't aware of. This is quite a steep learning curve.
Reply #14 on:
January 27, 2003, 17:02 »
It's also worth making the effort of ensuring the digibox is plumbed through your VCR, Clive, so that recordings are also made in true widescreen. Any VCR worth it's salt will automatically detect 16:9 record / playback.
