Author Topic: dvd burning  (Read 1382 times)
Offline pollard
dvd burning
« on: August 02, 2005, 23:01 »
When I copy files onto a DVD (or a CD), even only put a small amount of bytes, I am unable to add any more to the DVD (or CD).
Right click / info tells me the disk is full.
How can I cure this?  Bryan.
dvd burning
« Reply #1 on: August 02, 2005, 23:02 »
Can you tell us which software you are using?  Sounds like you might need to stop it from finalising the disc after burning.
dvd burning
« Reply #2 on: August 03, 2005, 00:56 »
As Simon says it sounds as if you are finalising the disc/s by not selecting the Multisession option, I think if you use XPs built in burning software then it doesnt have the option like 3rd party programs often do.
dvd burning
« Reply #3 on: August 03, 2005, 09:04 »
As Sandra said, Windows XP doesn't have the options, but if you are burning data CDs, it doesn't finalise anyway, as I have added to data backups in this way, many times.  If you are burning Audio CDs with XP, I think it will automatically finalise, but then most other burning software will do so also, unless there's an option not to.  Some CD players will not play unfinalised Audio CDs.
dvd burning
« Reply #4 on: August 04, 2005, 00:07 »
Try the free version of Deepburner.  Remember to tick the box "Create Multisession Disk".
http://www.deepburner.com/?r=products
The link is under "Download" on the right.
Offline pollard
DVD burning
« Reply #5 on: August 15, 2005, 23:31 »
Thanks to every one that has replied.
A search through the relevant files, and I found the option to finalise after recording box was ticked, so I unticked it!
I have high hopes that has done the trick.
Is it possible to unfinalise a disk?
Regards,
Bryan.
dvd burning
« Reply #6 on: August 16, 2005, 00:04 »
You can only unfinalise re-writable (RW) discs, which Nero can do, under Recorder > Erase Rewritable Disc.  Not sure about any other burning software, but I would think most would have the function somewhere.
