Author Topic: Autocad  (Read 783 times)
Offline pollard
Autocad
« on: August 15, 2005, 23:14 »
My last computer's op system was Windows 98.
I had Autocad LT loaded, which I used frequently for my own private purposes.
When I bought my current computer, (Windows XP home ed.) all my files from my old machine were transferred to my new one - including Autocad LT. (it is all there).
However, I cannot access it.
How can I overcome this problem?
Regards,
Bryan.
Autocad
« Reply #1 on: August 15, 2005, 23:29 »
You cant usually transfer an installed program Bryan, only the files that you created with it.
Are you sure that you have the exe for autocad on your new pc ?
Go to Start/Search and type Autocad.exe in and see if it can find it, I doubt that it will.
Have you got the original cd that autocad came on as I think that you will need to reinstall it again  :(
