Author Topic: compatability  (Read 779 times)
Offline jes`sys
  • New Registration
compatability
« on: August 27, 2005, 14:39 »
hi , wondering if anybody can help.
i`m going to buy a INTEL D915GAGL motherboard which has DDR 400 / 333 SDRAM Memory Support.
currently i have 2 ddr 256mb pc3200 installed on my current board. will this memory work on the INTEL D915GAGL board or will i need new memory aswell.
hope someone can help me out with this
compatability
« Reply #1 on: August 27, 2005, 15:06 »
Hi, and  :welcome:
You might find the easiest way is to go to CRUCIAL.COM, where you can check which memory is compatible with which motherboards.
Hope that helps.  :)
compatability
« Reply #2 on: August 27, 2005, 15:35 »
It should work fine, DDR isnt usually as fussy about the mobo as SDRAM was.
PC 3200 is 400 DDR so thats the fastest and best type of ram for your board  :)
