Author Topic: monitor cleaning  (Read 1198 times)
Offline KRO
monitor cleaning
« on: August 27, 2005, 18:14 »
hi, sorry if this is under the wrong heading but can anyone tell me the best way to clean my LCD monitor screen please
thanks keith.
cheers kro.....
monitor cleaning
« Reply #1 on: August 27, 2005, 19:50 »
Hi Keith,
You could try THIS.  ;)
But if that doesn't work, all I use is everyday glass / window cleaner, with a lint free polishing cloth (or something similar which doesn't smear).
monitor cleaning
« Reply #2 on: August 27, 2005, 19:51 »
I paid £15 for a proper screen cleaning kit but it just turned out to be sachets containing cut-down windscreen cleaning "wet wipes."  You may as well go to your local Halfords and buy a pack of "Screenies" costing under a fiver because I can assure you that they are made of identical material and the solvent in both is isopropyl alcohol.  You will end up with a much larger pack too!
Tip:  Brush off all the dust with one of those wonderful Flash dusters first.  LCD screens are very soft and easily scratched by dust particles.
monitor cleaning
« Reply #3 on: August 27, 2005, 19:59 »
Quote from: "Clive"
I paid £15 for a proper head polishing kit but it just turned out to be sachets containing cut-down windscreen cleaning "wet wipes."
At least you can use them for your glasses too!  :grin:  :scoot:
monitor cleaning
« Reply #4 on: August 27, 2005, 21:11 »
Ooooh!  words such as pot, kettle, and black come to mind!   :splat:
monitor cleaning
« Reply #5 on: August 27, 2005, 23:16 »
monitor cleaning
« Reply #6 on: August 28, 2005, 19:51 »
now dried on "boggies" they are bugger to shift of LCD screens  :D
