April 07, 2025, 22:43
Technical Help & Discussion
winmx ?
Topic: winmx ? (Read 1211 times)
Michelle
winmx ?
September 21, 2005, 22:39 »
Is there summit going on with winmx - it won't connect and the main webpages appear to be gone? Have they been done? Or is it me :shock:
winmx ?
September 22, 2005, 00:19 »
i havent used that in years...likely it finally went the way of kazaa!
Reno
Established Member
ø¤º° bob °º¤ø
winmx ?
September 22, 2005, 04:27 »
Limewires about to go along with it. What are the new networks popping out nowadays?
winmx ?
September 22, 2005, 07:37 »
for music i use a piece of software called soulseek apart from music, these days, i dont bother with any other sort of file sharing so I can't help. Any ideas anyone?
DJ
Established Member
winmx ?
September 22, 2005, 09:37 »
Have a look at
http://www.theregister.co.uk/2005/09/22/p2p_networks_darken/
Seems WinMX and eDonkey have had their day.
DJ
Michelle
winmx ?
September 22, 2005, 12:55 »
Thanks DJ that explains it, I couldn't find anything about it.
At least its not my puter messing up
Camstop
Loyal Member
winmx ?
September 22, 2005, 15:23 »
I think Limewire is great and certainly the best i've used and will be sad to see it go if it does :roll:
Michelle
winmx ?
September 23, 2005, 07:21 »
I might try that soulseek then sam, thanks. Or limewire but there days look numbered then.
winmx ?
