Author Topic: Norton and Java problem  (Read 1595 times)
Offline momad30044
« on: October 01, 2005, 00:15 »
Our public library is online so I'm able to renew books etc.  Within the last week or so, when I try to access the site I get a JAVA message that says "No proxy."  There's actually more to the message than that, but the computer then freezes and I have to shut AOL off and start over.  Any thoughts?  My computer is a Gateway laptop with Windows XP.  I've checked with the library and they've not had any complaints from anyone else, so it's definitely a problem with my computer.
My other question is in regards to Norton and McAfee.  They came loaded on the computer and I hate them.  Norton pops up almost constantly and I can't figure out how to shut it off.  I prefer to use AVG and Ad-aware...Do I need to keep Norton and McAfee?
Thanks for any suggestions.
Debbie
« Reply #1 on: October 01, 2005, 01:32 »
Hi Debbie, glad you managed to get back in  :)
Its not a good idea, I dont think, to have two AV programs running on the same pc.
If you prefer AVG then uninstal Norton and Macafee and just run with AVG.
Can you access it the next time round or are you unable to access the library page at all ?
Online Simon
« Reply #2 on: October 01, 2005, 09:50 »
Just a thought, but is it Norton Firewall and McAfee Anti Virus?  They would work OK together, as long as you were not also running Windows Firewall.  It could well be Norton Firewall which keeps 'popping up'.  Anyway, as Sandra said, you can uninstall them and change to what you want.
