July 05, 2024, 15:53
Technical Help & Discussion
disk boot failure??
Topic: disk boot failure?? (Read 1088 times)
POSTMAN477
Regular Member
disk boot failure??
October 08, 2005, 20:09 »
just adding op system but get disk boot failure,any ideas ??/
Sandra
Ultimate Member
disk boot failure??
October 08, 2005, 21:50 »
Sounds like you have not set the bios to boot from CD rom as first device.
Once you have set the bios restart the cd in the drive and press any key when you see press any key to boot from cd rom at the bottom of the screen.
Do not press it again when it reboots or you will go round in a loop
POSTMAN477
Regular Member
disk boot....
October 08, 2005, 22:36 »
Yes its set to boot from cd first then hd second...disk is in it just says disk boot failure,insert system disk and press enter....
disk boot failure??
October 08, 2005, 23:16 »
Check the IDE connections on your CD Rom(s) and Hard Drive. This happened to a friend of mine, and it turned out to be a dodgy IDE lead to the hard drive.
Sandra
Ultimate Member
disk boot failure??
October 09, 2005, 00:48 »
As the pc starts does it detect the cd drive correctly on the first screen just after the memory and the hard drives ?
Also if you have two cd/dvd drives it may only boot off one of them, if you have two drives try it in the other drive.
POSTMAN477
Regular Member
another problem....
October 09, 2005, 19:47 »
wel thanx i sorted it in the end....just a dodgy copy of xp wouldnt boot....
but now starts loading and says cant continue no hard drive detected...its a sata connection...is there anything i shoud do to hard drive before instaling os?
disk boot failure??
