April 06, 2025, 12:46
Technical Help & Discussion
Anyone know if you can save files to the H/D in Swish trial?
Topic: Anyone know if you can save files to the H/D in Swish trial? (Read 757 times)
TOFFEEMAN1878
Regular Member
October 16, 2005, 11:39 »
Or do I have to buy it, to it use for full function .
Thanks in advance ...Jim
October 16, 2005, 12:04 »
I think you can, Jim. From what I remember, the limitation is that it stops functioning after 30 days.
P.S. You have a PM.
