July 05, 2024, 16:38
Technical Help & Discussion
General Tech Discussion, News & Q&A
Low or No connectivity
Topic: Low or No connectivity (Read 2380 times)
TOFFEEMAN1878
Regular Member
November 06, 2005, 22:47 »
I keep getting this message inthe system tray & have to reboot to get the connection working again ,anyone any idea what is causing this problem ?
I am using a router to connect to the net !
Thanks in advance .....Jim
November 06, 2005, 23:40 »
Hi Jim,
You might want to wait for Sandra to see this before taking any of my advice, but having done a bit of Googling, it seems there may be a bug in Windows XP SP2, which could cause your symptoms, although I have to say, the error message given is not identical to yours. Lots of info in the link below, however, including downloadable Microsoft patches:-
http://www.pchell.com/support/limitedconnectivity.shtml
Sandra
Ultimate Member
November 07, 2005, 00:40 »
Have you tried going into your network connections folder when you get this message and right clicking on your LAN icon and selecting repair ?
When I have seen that its usually because the LAN IP address has fouled up and its assigned one for a pc to pc instead of a pc to router one, usually in the 169.xx.xx.xx range.
Have you tried rebooting the router as well as the pc so that the router can reassign the LAN IPs ?
TOFFEEMAN1878
Regular Member
November 07, 2005, 10:14 »
Hi Sandra, I have tried to repair the way you suggested ,no go there ,next time it happens will reboot router as well .
thanks for your help .....Jim
Sandra
Ultimate Member
November 07, 2005, 12:13 »
Did it give you a message similar to " Unable to renew IP address" when you tried to repair the connection ?
TOFFEEMAN1878
Regular Member
November 07, 2005, 16:28 »
Yes it did , I followed Simon's suggestion so maybe that will work .....Jim
Sandra
Ultimate Member
November 07, 2005, 16:32 »
The unable to renew IP is usually sorted by rebooting both the router and the pc at the same time.
Anyway the main thing is that its sorted by whichever method you used
TOFFEEMAN1878
Regular Member
November 13, 2005, 00:10 »
Came home tonight to find the message again ,anymore suggestions ?......Jim
Sandra
Ultimate Member
November 13, 2005, 01:05 »
Did you reboot the router as well as the pc ?
