Author Topic: Home page Hijacked!  (Read 1445 times)
Offline TOFFEEMAN1878
Home page Hijacked!
« on: December 09, 2005, 13:13 »
A friend of mine (in this case it is not me)  has had his homepage hijacked ,I know there is a way to fix this through the registery but I cant remember ,can anyone help ?......Jim
Home page Hijacked!
« Reply #1 on: December 09, 2005, 13:37 »
A good start is to download and run AD-AWARE
and then SPYBOT SD
If it's still there after that come back and let us know.
Offline Scotty_CFC
Home page Hijacked!
« Reply #2 on: December 09, 2005, 13:41 »
I don't know if its the way you're talking about, but I fixed my hijack by editing the following iereset file with notpad. C:\windows\inf\iereset.inf
Home page Hijacked!
« Reply #3 on: December 09, 2005, 13:49 »
It was something like :   Current User > Sofyware>Mircosoft >Windows>Run
then after that I can't remember !!!
                         :x  :x  :x  :x
Home page Hijacked!
« Reply #4 on: December 09, 2005, 16:26 »
Does resetting it in Tools/Inernet Options not work ?
CWS Shredder is quite good at removing the cool web home page hijacker, if not.
Home page Hijacked!
« Reply #5 on: December 09, 2005, 18:16 »
Resetting it in Tools/Inernet Options usually only works until the next reboot.  CW Shredder is a good idea but also try http://www.x-raypc.com/
which is a registry scanner that will alert you to malware and help to remove it.  If that doesn't work then there are other options available.
Offline Hiatus
    • JoshSalverda.com
Home page Hijacked!
« Reply #6 on: December 09, 2005, 20:21 »
HijackThis usually works quite well for those kinds of things...It lists all the current programs/registry values running, you can then select individual parts and delete them. You can also save a log and post it here if need be.
There should be a section like this:
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.google.ca
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://www.mdg.ca
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page_bak = http://www.google.ca/
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = Microsoft Internet Explorer provided by Sympatico
Which is where the problem will most likely be...
l33t h@x0r... sort of...
Home page Hijacked!
« Reply #7 on: December 10, 2005, 00:20 »
Hiatus,Thanks for the info........Jim
