Author Topic: Latest version of Zone alarm  (Read 792 times)
« on: December 30, 2005, 20:08 »
Hi all
I seem to remember that a while back (bit vague on how long ago) there was an issue when running the latest (then) version of ZA with NAV, in that the ZA antivirus stopped NAV from working.  Does anyone know if there are any issues with the latest ZA and NAV.  I'm currently running NAV 2003 and ZA 4.5.594 successfully on my old pc but would like to put the latest ZA on my newish pc  :wink:
« Reply #1 on: December 30, 2005, 20:40 »
umm i recall somethng along those lines but cant remember. I use AVG and havent had an issues with zone alarm, but thats not very useful. Hopefully someone else has more info. Might be worth check on the zone alarm website / AVG site to see if thay have software incompatibilies listed.
« Reply #2 on: January 01, 2006, 16:12 »
Actually Sam i'll probably use AVG + ZA on my new pc to see if they're any faster, nav really seems to slow things down  :D
« Reply #3 on: January 01, 2006, 17:50 »
nav is crap for memory usage (it really needs loads!), it really can kill your machine... the main reason i dont use it.
