Author Topic: MY motherboard Asrock, i guess  (Read 1968 times)
Offline peruvianpisco
« on: January 11, 2006, 12:35 »
Hello, since i got a new mobo, an Asrock P4i45GV, it turns on for a moment, i mean it sounds like a normal start one second, (cooler works, no beeps), then it stops and resume again, always start two times so i always thought it's normal..but is it?
I say start, maybe i must say boot, you know i suck in english  :blush:
Thank you in advance
here are 10 types of people, people who thinks in binary and people who doesn`t
« Reply #1 on: January 11, 2006, 12:37 »
Do you mean that it starts then shuts down and then restarts by itself or do you have to push the button again ?
« Reply #2 on: January 11, 2006, 20:23 »
Hi,
It restarts by itself...and always does it
« Reply #3 on: January 11, 2006, 21:46 »
Do you mean Windows fully loads, then restarts, or is this happening within a few seconds of you switching on the machine?
« Reply #4 on: January 12, 2006, 00:16 »
I think its doing it before it loads the bios Simon  :?
Its probably not loading the GFX drivers properly but I cant understand why it reboots itself  :?
« Reply #5 on: January 12, 2006, 01:46 »
Right Sandra, it is just a moment, no time to display anything .. i thought it was a feature to check the power supply or the voltage because it is new, i assumed it was right, now i am worry
« Reply #6 on: January 12, 2006, 02:25 »
Well as long as it does start without you having to do anything I wouldnt worry too much.
Does it start ok if its just been shut down for a few minutes or is it always the same ?
It almost sounds as if the power supply is "soft" starting so it needs to build up its power doesnt it but I havent heard of anything being designed to do that on a pc  :?
« Reply #7 on: January 12, 2006, 17:54 »
It always started the same way, i guess one second between the false and "true" start.
« Reply #8 on: January 13, 2006, 00:29 »
Is it a new power supply or have you used it in another pc or with a different motherboard before ?
« Reply #9 on: January 13, 2006, 05:29 »
It's a new one, i tried with another one, new too, and the same thing happened, rated 500w both, all is new except the case
« Reply #10 on: January 13, 2006, 13:57 »
Unless its a bios setting then I have no idea on that one  :?
ok
« Reply #11 on: January 13, 2006, 15:51 »
Ok, thank you  ... it's strange
