Author Topic: PSU 24 Pin does not fit my 20 pin motherboard  (Read 2073 times)
Offline zephra
« on: January 18, 2006, 00:13 »
bought a power supply for my computer.Good deal.I never checked that my motherboard is a 20 pin Molex.Now my new 24 pin PSU wont work.Anyone sell adapters for this and do they work???
« Reply #1 on: January 18, 2006, 00:15 »
I believe that there are some around but havent actually seen any.
Offline zephra
psu
« Reply #2 on: January 18, 2006, 00:24 »
I heard the other 4 pins are for pci express.I am pretty handy with molex connections.But will it work??
« Reply #3 on: January 18, 2006, 00:32 »
Originally ATX mobos were 20 pin then they had some 20 + 4 and sometimes they had a single 24 pin as you psu has.
I have heard of people using the 20 pin and the seperate 4 pin side by side to make the 24 pin but I dont know how they get around the lugs that stop them being connected incorrectly, maybe they just slice the lug off ?
Presumably you could chop the extra 4 off, if your mobo doesnt need them and modify the connector but I would like some verification that this was safe before I suggested you did it  :?
Offline zephra
searched around
« Reply #4 on: January 18, 2006, 00:46 »
Seems like everyone has the opposite issue then me.They have a 24 pin mobo and a 20 pin psu.They do sell adapters for this.No luck finding a 24 pin psu to 20 pin mobo adapter yet
« Reply #5 on: January 18, 2006, 02:05 »
I think that you will have to compare your old PSU and the new ones and make sure the same wires are in the same place in relation to the 20 pins that are on the old PSU and then either use the old connecting block or modify the new one somehow  :(
« Reply #6 on: January 24, 2006, 01:34 »
My parts supplier sells them, so i konw they're out there. I think the last one i bought was about 3 bucks.
Theres something i just googled up.
http://www.xpcgear.com/24to20pinatx.html
Offline JK
« Reply #7 on: March 10, 2006, 22:55 »
Are you sure that the extra 4 pin part does not snap off?
I have just fitted a new power supply and thought that I had the same problem, until  found out.
« Reply #8 on: March 11, 2006, 00:13 »
They've redesigned the new 24 pin power supplies to have that snap off part. It came along a couple months after they released the 754 socket montherboards. Easier then buying the little adapter.
