Author Topic: Flash website  (Read 4902 times)
Offline DJ
Flash website
« on: January 23, 2006, 16:28 »
Hi All,
I want to build a site similar to the one at http://www.neave.com
Can anyone suggest any books / ebooks / sites that would help me.
I have some experiance of dreamweaver and HTML, but very little experiance of Flash.
Also do I need any special hosting features for flash?
Thanks all
DJ
Flash website
« Reply #1 on: January 23, 2006, 17:12 »
I dont think you need anything special for flash files on a normal website.
If you get a program such as Swish or Swish Max you will soon pick it up and there are plenty of tutorials on how to use it on the main site at :
http://www.swishzone.com/
Offline DJ
Flash website
« Reply #2 on: January 23, 2006, 17:30 »
Thanks Sandra your a Star!!
I was looking at Macromedia Flash, but Swish looks a lot easier to use.
I'll have a look at it once I get a spare few minutes and see how much I can cobble togehter.
Cheers :thumb:
DJ
Flash website
« Reply #3 on: January 23, 2006, 19:04 »
dont do it dj! flash sites are the scurge of the world!
Offline DJ
Flash website
« Reply #4 on: January 23, 2006, 22:58 »
Quote from: "sam"
Don't you like the one at www.neave.com ?
I just want to design one that is really straight forward to use and quite unusual.
DJ
Flash website
« Reply #5 on: January 23, 2006, 23:07 »
Ignore him, DJ!  He's just a Flashist!  :grin:
Flash website
« Reply #6 on: January 24, 2006, 08:14 »
:funnypost:
Offline Camstop
Flash website
« Reply #7 on: January 24, 2006, 08:43 »
Quote from: "DJ"
Quote from: "sam"
DJ
I feel quite sea sick now  :blush2:
Flash website
« Reply #8 on: January 24, 2006, 09:40 »
well said cam! :-)
I just think that website should use (x)html or some with some webspecific programming langauge (i.e. php or asp) to get the job done. Using flash really cuts of users who don't have flash installed. Oh and btw that includes me at work... which was bliss when si had his damn xmas flash banner :-)
Flash is great for games and other animations but for the main content of a website then eeewww. :-) But thats just my opinion maybe I am just a flashist (I like that term!) but you will find that I am not the only website designer who is.
Offline DJ
Flash website
« Reply #9 on: January 24, 2006, 10:12 »
Fair comments Sam, probably why I haven't try to build a site in flash yet. Always stuck to HTML with CSS or PHP.
Just wanted to try something different.  Think I'll still have a go and see how I get on.  Will probably end up with a basic HTML site instead!
DJ
Flash website
« Reply #10 on: January 24, 2006, 23:27 »
indeed.. heck its fun to play..and i'd encourage that you did... its not like i havent played with flash in the past.
Offline DJ
Flash website
« Reply #11 on: January 29, 2006, 17:32 »
Is it possible to convert FLA files to SWF and then edit them in Swish?
Help someone  :D
Thanks
DJ
Flash website
« Reply #12 on: January 29, 2006, 20:46 »
Unless I'm mistaken, and I could well be, I think you can use the Import facility in Swish (File > Import), which will convert them to an editable format, then you should be able to Export it again (File > Export) to a SWF file, but I don't think it will allow you to Export back to a FLA.
Offline DJ
Flash website
« Reply #13 on: January 29, 2006, 22:31 »
Quote from: "Simon"
The File > Import menu doesn't include the .fla extension.
Next suggestion  :wink:
DJ
