Author Topic: Excel Formula Query  (Read 1189 times)
Offline DJ
Excel Formula Query
« on: January 24, 2006, 22:54 »
Hi All,
I need to be able to reference a sheet name in my formula, dependant on what the user enters in a cell. Let me explain.
Say I have a workbook with Sheets named Summary, Jan, Feb and Mar.
The formula I could use on a Summary sheet is like...
Code: [Select]
=Jan!A1 + A2
But I want to control this by the users data entry in a cell adjacent to this, so that whatever is entered in a cell replacess the "Jan" bit.
So if the data is entered in cell D1 I thought I could use
Code: [Select]
='D1'A1 + A2
But it doesn't seem to work - can anyone shed any light? I hope I have explained this ok.
Basically the sheets can be named anything and so the forumla to calculate this needs to be altered each time - so referencing to another cell would be ideal.
Thanks
DJ
Excel Formula Query
« Reply #1 on: January 25, 2006, 01:26 »
Without knowing exactly what your parameters are, my meagre knowledge is insufficient :( .  Nevertheless, I'm sufficiently confident (after a night out dancing and at the pub :oops:) to suggest the answer might lie in the 'And' argument.
Gill
Offline DJ
Excel Formula Query
« Reply #2 on: January 25, 2006, 09:33 »
All I want to do is replace the Sheet name (Jan!) with a cell reference (e.g. D1).  So that whatever is typed in D1 is a sheet name.
DJ
Excel Formula Query
« Reply #3 on: January 25, 2006, 18:00 »
DJ,
Does this seem right  :wink:
A formula to put the sheet?s name into a cell
=RIGHT(CELL(?filename?,A1),LEN(CELL(?filename?,A1))-FIND(?]?,CELL(?filename?,A1)))
The CELL() function with the ?filename? argument will return the full path of the workbook plus the sheet name. The workbook will be enclosed in brackets []. This formula finds the right bracket (]) and returns everything after that.
Note that if the workbook has not been saved, there is no path, and this formula returns a #Value error.
TR
Or have I got the wrong end of the stick again  :twisted:
Offline DJ
Excel Formula Query
« Reply #4 on: January 26, 2006, 19:11 »
Nope - thats exactly the right end of the stick!!
Thanks TR
DJ
Excel Formula Query
« Reply #5 on: January 26, 2006, 22:03 »
Oh, well done, Terry!  We know who to come to with Excel queries now.  :thumb:
Excel Formula Query
« Reply #6 on: January 26, 2006, 22:57 »
Lucky Guess I guess  8)
But then again  :wink:
Phewwww another bluff   :nerd:
Where's the sticky out toungue when you want it  :twisted:
Excel Formula Query
« Reply #7 on: January 26, 2006, 23:19 »
What, this one?   :tongue:
