Author Topic: Convert composite to VGA  (Read 1849 times)
Offline Hiatus
    • JoshSalverda.com
« on: February 09, 2006, 05:01 »
Hopefully there are some fellow electronics geeks out there somewhere...
Anyone know how to convert a composite video signal to VGA?
I know there are devices out there that can accomplish this, but does anyone know how to build one from scratch?
I don't like to spend money on stuff I can build myself, lol... I've been searching on the net but everything seems quite complicated...I'm not overly smart with electronics, but I do know quite a bit.
I might just have to give up and buy one eventually... then maybe open it up and see how it's done, :D.
l33t h@x0r... sort of...
« Reply #1 on: February 09, 2006, 09:42 »
I saw a wiring diagram recently for VGA to RGB Scart but I cant imagine that youd get composite to VGA as youd only have two wires connecting to a 15 pin plug or socket  :?
If you dont mind me asking, why do you want composite to VGA as composite is the lowest video standard and VGA is much higher  :?
Offline Camstop
« Reply #2 on: February 09, 2006, 09:53 »
The units are used so you can display composite on a TFT
Description
Complete with credit card sized IR Control. Convert Video or S-Video into VGA Signal. Perfect to make a CCTV Camera work onto a VGA / TFT Screen. Supplied with PSU. New Enhanced Model which uses 12v regulated supply so can fit into most CCTV installations. Auto turn on with power loss to default resolutions and refresh rate ideal for LCD Monitors. New Product Released September 2005
That's the only ones i know about  :dunno:
« Reply #3 on: February 09, 2006, 10:01 »
Have you seen one in action Cammy ?
I should imagine it would be a crappy picture wouldnt it  :?
Offline Camstop
« Reply #4 on: February 09, 2006, 10:12 »
Yes
They are not quite as good as CRT but ok for non critical situations  :nerd:
Should depend on the video source and the monitor i'd think.
« Reply #5 on: February 09, 2006, 15:33 »
Is this something similar to what you were looking for?
http://www.aver.com/2005home/product/pc_to_tv/pc_to_tv.shtml
Code: [Select]
Input Signal: VGA, RGB or MAC
Horizontal Frequency: 31KHz - 108KHz
Vertical Frequency: 56Hz - 120Hz
Output Signal: Composite, S-Video, RGB, Computer Monitor (PC or MAC) Pass-Thru Output
Power Supply: 12V DC Power Adapter
Dimensions: Base unit : 5.95" x 4.76" x 1.45"
Weight: 0.77 lbs
Warranty: 1 Year Parts & Labor
Compliance: FCC Class B
I use to install them in high school for the teachers tv presentations. I have one on my shelf i haven't used in four years.
Offline Hiatus
    • JoshSalverda.com
« Reply #6 on: February 10, 2006, 15:42 »
I'm using my computer as my TV, so I don't actually have an actual television. So I just wanted to know if I could hook-up one of my old systems (N64, or SNES) to my monitor to act like a TV... I can't use the TV tuner because of the lag between the controls and the graphics.
So I was thinking that if I hooked up the system directly to the monitor it would solve everything...
I also saw a wiring diagram to convert to RGB... I even have the instructions:
splicing pins 1 and 6, 2 and 7 and 3 and 8 while shorting 4 and 5 as vsence (ground). Each of those pairs in that order are; RED, GREEN and Blue.
But then I need to get from there to composite... which I think involves quite a bit of electronic-type stuff, lol...
The closest I got to figuring this out was this: http://elm-chan.org/works/sc/report.html
But that's an s-video input.
