Author Topic: cpu clock ratio  (Read 1699 times)
Offline peruvianpisco
cpu clock ratio
« on: February 14, 2006, 14:15 »
Hello
There is something i don`t understand, i got Award software- cmos setup, i got cpu host clock 100 and cpu clock ratio X4  , well, but no matter if i change this value, always i got 100 x 12 ( the maximum because i use celeron 1,2 ghz).. i don`t know how this value is unable to change, the manual of my jetway mobo doesn`t say anything about multiplier jumpers. just bus clock.
This 100 x 12 appears in POST and Everest , so it`s real...what`s happening?
Thank you in advance
here are 10 types of people, people who thinks in binary and people who doesn`t
cpu clock ratio
« Reply #1 on: February 14, 2006, 15:38 »
Some CPUs are locked and you need to unlock them in order to alter the multiplier.
Different CPUs use different methods and some cant be unlocked.
Its not something I have ever done though.
I prefer to leave the CPU settings at default as that causes less problems usually.
mmm so, it was..but
« Reply #2 on: February 14, 2006, 19:19 »
Ok, thank you, that explains all...so that is the reason why it can`t be used with mobo supporting less than 1 ghz, with the same socket, or am i wrong and this is another of my newbie stuff? :D
cpu clock ratio
« Reply #3 on: February 14, 2006, 19:27 »
I am not 100% certain but I think thats the answer.
