Author Topic: Excel - CountIf - Multiple Criteria  (Read 1497 times)
Offline DJ
« on: February 20, 2006, 15:27 »
Hi All,
Another excel questions  :laugh:
I have one sheet that is in the format of (basically);
Month     Cust    Invoice No     Fees     Exp
Months are Jan, Feb etc. Cust is a choice of 5.
I want (on another sheet) to count the number of invoices done for each customer on a certain month.
So I thought I could do a coutif function, but unsure how to use it for multiple criteria.
Any ideas?
Thanks
DJ
« Reply #1 on: February 20, 2006, 22:06 »
ummm im unsure, ill have a think for ya tomorrow when my mind is actually awake.
Offline DJ
« Reply #2 on: February 20, 2006, 22:38 »
Think I've got it
Code: [Select]
{=SUM(('Sheet1'!$C$5:$C$600=CustA)*('Sheet1'!$U$5:$U$600=June))}
Now another one!!....
How do I change this so that it Sums a certain column, if the Cust is CustA, Month is June and the values I to sum are in E5:E600
Cheers :thumb:
DJ
« Reply #3 on: February 21, 2006, 18:15 »
ummm
Offline DJ
« Reply #4 on: February 21, 2006, 22:31 »
Don't worry - think I'm getting somewhere - slowly....  will post back soon.
I have this habit of posting a question then working out the answer myself !  :blush:
DJ
« Reply #5 on: February 21, 2006, 22:55 »
oh no thats a good thing.... and if you dont sort it by tomorrow i'm sure my mind will have a moment of inspiration.... i could write you an idl script that would do it in no time, but thats useless to u
« Reply #6 on: February 22, 2006, 17:38 »
Quote from: "DJ"
Think I've got it
Code: [Select]
Cheers :thumb:
DJ
DJ sorry I missed this one  :blush:
I have tyried this out on my spread sheets and it works with mine but dont know if it does on yours?
{=SUM(('Sheet1'!$C$5:$C$600=CustA)*('Sheet1'!$U$5:$U$600=June))}($u$5:$u$600)
tr
Offline DJ
« Reply #7 on: February 22, 2006, 21:20 »
Yes - sorry forgot to update this.
Everything is working. Forgot to CTRL + SHIFT + Enter to make the array formula work.
Cheers :thumb:
DJ
