Author Topic: Cheap Dial Up?  (Read 1321 times)
Cheap Dial Up?
« on: February 25, 2006, 09:47 »
Can anyone recommend a cheap, pay-as-you-go dial up service?  My back up dial up is discontinuing as from the end of this month.  Ideally, the new one should be free of any complex registration requirements.
Offline Camstop
Cheap Dial Up?
« Reply #1 on: February 25, 2006, 09:50 »
This one's good Si
http://www.freewire.net/
Cheap Dial Up?
« Reply #2 on: February 25, 2006, 14:09 »
Plusnet is pretty good too.  All you have to do is check your e-mail box once every few months but they will send you a reminder anyway.
Cheap Dial Up?
« Reply #3 on: February 25, 2006, 14:33 »
Quote from: "Camstop"
This one's good Si  http://www.freewire.net/
Yeah, I looked at that one myself, John, but really I could do with one that I can send e-mails with.  I realise you can with Freewire, but it seemed like quite a complicated set up procedure, and I don't want to risk downloading one of those dial up configuration things which takes over and brands everything.  Maybe I've not looked into it fully enough.
Clive, yes, I have used PlusNet previously.  Might be worth a look.
Cheap Dial Up?
« Reply #4 on: February 25, 2006, 14:40 »
Quote from: "Simon"
You might be interested in this one, Simon.  The smtp configuation details are on the front page with the number, username, and password.
Cheap Dial Up?
« Reply #5 on: February 25, 2006, 14:48 »
Thanks Dave - that looks like the one!  :thumb:
