Author Topic: Internet speed  (Read 1666 times)
Offline DJ
Internet speed
« on: February 28, 2006, 22:47 »
Just a quickie  :blush:
Does your broadband router have a direct effect on the speed of your connection. For example I have 2mb broadband connected through a netgear dg824m router.  The connection seems slower than other 2mb broadband that I have witnessed.
What else has an effect on the internet connection? Processor speed? Memory? BT Line?
Any suggestions on how I can increase the broadband speed is much appreciated.
Cheers :thumb:
DJ
Internet speed
« Reply #1 on: February 28, 2006, 23:19 »
Even a slow pc is much faster than a 2mb connection.
Its probably your BT line, unless your ISP is throttling some of your ports for some P2P activity that you are using.
Internet speed
« Reply #2 on: February 28, 2006, 23:26 »
I have 1MB broadband and it is just as fast (or should that be slow) as 2MB connections that I have used at other peoples' houses.  For example, if I'm feeling brave and download Windows Updates, I get a download speed of between 90KB/s and 120KB/s.  If I am at my sister's and download Windows Updates on her 2MB connection, the speed is exactly the same.  I suspect that the infrastructure isn't really up to anything more than 1MB.
Offline Camstop
Internet speed
« Reply #3 on: March 01, 2006, 09:44 »
Have a go on this DJ
http://www.adslguide.org.uk/tools/speedtest.asp
I also have a 2Mbps connection and a Netgear router and my results were...
Downstream     1890 Kbps (236.3 KB/sec)     2041 Kbps (inc. overheads)
Upstream    255 Kbps (31.9 KB/sec)    275 Kbps (inc. overheads)
Offline DJ
Internet speed
« Reply #4 on: March 01, 2006, 09:53 »
Thanks all.
Had a go at the speed test and get similar results to camstop...
Downstream   1886 Kbps (235.8 KB/sec)    2036 Kbps (inc. overheads)
Upstream       245 Kbps (30.6 KB/sec)        264 Kbps (inc. overheads)
Must be my imagination!
DJ
Internet speed
« Reply #5 on: March 01, 2006, 10:07 »
Ditto!
Downstream 1880 Kbps (235.0 KB/sec) 2030 Kbps (inc. overheads)
Internet speed
« Reply #6 on: March 01, 2006, 10:33 »
I'm only on a 1Mb service, but relatively, my results are also satisfactory:-
Downstream     936 Kbps (117.0 KB/sec)     1010 Kbps (inc. overheads)
Upstream    246 Kbps (30.8 KB/sec)    265 Kbps (inc. overheads)
Internet speed
« Reply #7 on: March 01, 2006, 11:51 »
It's interesting that your upstream is faster than mine Simon!
Internet speed
« Reply #8 on: March 01, 2006, 21:12 »
Probably just your age, Clive.  :mmm:   :twisted:   :grin:
