November 28, 2024, 01:43
Technical Help & Discussion
General Tech Discussion, News & Q&A
Autorun .txt file?
Topic: Autorun .txt file? (Read 2108 times)
Autorun .txt file?
March 06, 2006, 22:39 »
I want to create a CD with an Autorun .txt file, so that when the user loads the CD, a Readme I have written appears, instead of the installation automatically launching. Can this be done, and if so, how do I create an Autorun file of this nature?
DJ
Established Member
Autorun .txt file?
March 06, 2006, 23:26 »
Hi Simon,
**EDIT** SORRY - Looks a bit more complicated - see
http://www.phdcc.com/shellrun/autorun.htm
Make a text file called autorun.inf and include the following
Code:
[Select]
[autorun]
open=readme.txt
icon=readme.ico
Replace the readme.txt with whatever your readme file is called.
That should work.
Have a look at
http://autorun.moonvalley.com/autoruninf.htm
for more info.
DJ
Autorun .txt file?
March 06, 2006, 23:39 »
Thanks DJ, just what I needed.
Autorun .txt file?
