heya! can anyone help me with this?
I've just bought a data transfer cable for my phone, the model is NEC e313, and the cable is called a 616, but it works for this phone as well.
basically, i'm pretty sure i've installed everything right, following all instructions and with extra help from other sites etc
but
when i go into the file transfer centre, and try to getpictures etc from the phone to the computer, it comes up with an error message that says "Handset not detected. Please check connection"
I have checked all connections, reinstalled things, done everything you would normally do, and asked all round, but nobody can figure out the problem :?
so if anyone can help you will be eternally loved
hehe
and you may have an invisible gold star
*waves the star around enticingly*
thanks!
:D Vicky x x x x x x
