As some of you may know I recently bought what I thought was an execllent pc from Aldi.
The Medion 8800 at a cost of £749 - 99
On paper it was a very well spec'd pc complete with twin digital terrestrial and satellite tv tuners.
It had a 3ghz Intel dual core CPU, 1 gig of DDR2 ram, a PCI-e graphics card, a 250 gig SATA hard drive and a 16 x DVD writer with Light Scribe feature.
Unfortunately the TV side of it didnt work properly, until ironically after I had arranged to return it to Aldi for a refund, and the recorded analogue audio in didnt work, that still hasnt been sorted for other users as far as I know.
I had already bought a case to build myself a new PC 2 weeks before I saw the Medion one advertised and bought that instead so I reverted back to plan A.
This is a list of the parts and prices of my new PC :
Chietec Case Mesh Series LCX-01SL-SL-B £64 ? 80
5 x 92 mm 4 pin molex connector case fans, unknown make £12 ? 98
Fan controller for 3 connections £4 ? 98
All the above were brand new from Ebay sellers.
Asus P5WD 2 Premium motherboard £135
Intel Pentium 4 660 3.6Ghz Socket 775 800Mhz 2mb Cache £208
Should have been £270 but got a good deal.
2 x 1 gig Corsair DDR2 533 ram £121
MSI NX 6800 GS 256mb DDR3 PCI-e GFX card £148
Hiper 580W Type-R Modular PSU £65
LG GSA-4167BAL 16 x DVD writer inc RAM £27
Liteon SHW-16H5S 16 x DVD writer inc Light Scribe £30
1 x 120mm Thermaltake LED case fan £9
All the above came from Mustafa at
www.muson.com, a local store.
WD2500JS Caviar SE 250GB SATA2 8MB Cache - £65 ? 93
WD2500KS Caviar SE 250GB SATA2 16MB Cache £66 ? 37
Hard drives from Ebuyer plus postage
Tv Tuner bundle from Nebula inc VAT and delivery was £135 ? 82
http://www.nebula-electronics.com/information/info.asp?Code=0601Spare floppy that I had already say £5
Total cost of pc £976 ? 88
Extras :
Grand Hand View universal VGA/ PC to TV converter box, new from Ebay.
only necessary as my tv has a fault that wont show a good picture unless its played into a RGB enabled scart.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=5863787853&rd=1&sspagename=STRK%3AMEWN%3AIT&rd=1 £29 ? 95
I changed the standard Intel CPU heatsink/fan for a Freezer 7 Pro so add another £19 - 73 inc vat and postage.
This was because of what I thought was a noisy cpu fan, unfortunately it made no difference as the noise is actually the fan on the GFX card
I also bought a BTC 9019 URF wireless keyboard with the joystick for £31 - 14 inc vat and delivery.
So including the extra bits its worked out at around £1,050
A third as much again as the 8800 but a far better pc in terms of performance, storage capacity and expandability.
I have added my WD 160 gig 8mb cache IDE drive complete with all the files on it that was in my old server pc and its now running my server and working as a media centre pc mainly for recording/watching TV on, and replacing my DVD player and VCR.
I should be able to update and upgrade it for a few years to come hopefully as well
