Author Topic: Disk Monitor Error message.  (Read 1659 times)
Offline Shaz
« on: March 11, 2006, 21:29 »
Hi All, my mates young brother had been messing with pc, basically her modem wasnt working and she couldnt get online, i sorted that by reinstalling but she also keeps getting a message after restarts ''DISK MONITOR BOX ,WITH MESSAGE 'FAILED TO GET DATA FROM COUNT'
Up to now if you just cancel message it dosent seem to be affecting anything but im just curious if anyone knows what this might mean and if it might affect certain areas of her pc?
 Thanks Shaz..  :D
een away but back with a vengence!!!!
« Reply #1 on: March 12, 2006, 00:06 »
Dont know why youre getting that message or what it is Sharon.
Get CCleaner from www.filehippo.com
Its a free program.
Install it and select the Fix Issues part.
That will scan and remove strange things from the registry which hopefully will fix or at least stop the message appearing  :)
Offline Shaz
« Reply #2 on: March 12, 2006, 01:51 »
Thanks San , will try it and let you know. :)
Offline Shaz
« Reply #3 on: March 12, 2006, 20:48 »
Hi San, I installed ccleaner also adaware,cleaned lots of rubbish off, freed up 340MBs :shock:
Rebooted and same box came up, so hasnt got rid of it, it doesnt seem to be affecting anything though so alls ok for now, would still like to get to bottom of it though, you know what im like.  :wink:
« Reply #4 on: March 12, 2006, 20:50 »
Have a look in the Startup Items part in MSCONFIG Sharon.
Maybe hes installed a program or started a service thats not working properly but is set to run at startup ?
