Author Topic: Weather Watcher - warning  (Read 1301 times)
« on: March 16, 2006, 16:56 »
I updated Weather Watcher yesterday aftert which I kept getting a very nasty pop-up that would not be tamed.  Ad-Aware showed it had dumped 17 pieces of spyware on me including WhenU exe which is a popup that advertises products it thinks you are looking for.  Needless to say I immediately uninstalled Weather Watcher and the popup has disappeared.
A better alternative is http://www.bbc.co.uk/weather/5day.shtml
« Reply #1 on: March 16, 2006, 17:22 »
You could try This one.
Very very acurate  8)
« Reply #2 on: March 16, 2006, 18:37 »
Thanks Terry.  It shows very bad weather for my area for the next 14 days.  Do you have anything that forecasts warm and sunny for me instead?   :grin:
« Reply #3 on: March 16, 2006, 20:16 »
I updated WW recently too, Clive, and I did notice there was an option to install something which was obviously adware, but it did give you a box to untick if you didn't want it, which of course, I unticked, and mine is fine.
« Reply #4 on: March 16, 2006, 23:23 »
Obviously I was not properly awake when I carried out the update!
« Reply #5 on: March 17, 2006, 00:02 »
It is very flashy now though, and I can't help thinking unnecessarily so.  I have an old version on file if you'd like it, Clive.  :)
« Reply #6 on: March 17, 2006, 08:14 »
Thanks Simon but I'll carry on using Terry's latest offering which seems to be accurate for today at least!   :laugh:
