Author Topic: System Restore interval settings  (Read 1732 times)
Offline Mac
« on: April 05, 2006, 17:20 »
The following are the standard settings.
System Restore makes a restore point every day and keep the restore points for three months...
Change Restore Point Creation Frequency
[Start] [Run] [Regedit]
Registry Key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\SystemRestore
Modify/Create the Value Data Type(s) and Value Name(s) as detailed below.
Data Type: REG_DWORD [Dword Value]  // Value Name: RPGlobalInterval
Setting for Value Data: [86400] Decimal
Change Restore Point Retention Lifespan
Data Type: REG_DWORD [Dword Value] // Value Name: RPLifeInterval
Setting for Value Data: [7862400]
I have mine set to make a restore point every hour and keep them for one day.
The time for one hour is 60 x 60 = 3600 as the RPGlobalInterval Decimal value.
And for one day is 24 x 60 x 60 = 86400 for the RPLifeInterval Decimal value.
When the settings have been changed close the Registry Editor and re-boot.
« Reply #1 on: April 05, 2006, 17:59 »
It never seems to function for me, and it's guaranteed not to work when you desparately need it to, so I wouldn't rely on it for backup purposes, but it sometimes comes in handy in certain situations - when it works.
Offline Mac
Drive Imaging is Preferable.
« Reply #2 on: April 05, 2006, 18:19 »
I prefer to rely on drive imaging and use TeraByte Unlimited's product range.
I never rely on System Restore as it has a tendency to restore any previous faults which it has picked up automatically.
If I add a program I put in an Admin Checkpoint manually before doing the installation, and that is all I use it for except to use it on an hour to hour basis during the day.
« Reply #3 on: April 05, 2006, 18:45 »
It also tends to store recalcitrant spyware or viruses, which is why it's always advisable to switch it off before doing any spyware / virus cleaning.
Offline Mac
« Reply #4 on: April 05, 2006, 18:49 »
Precisely.
It can be a nuisance, removing anti-virus updates, so that when you re-boot the AV scanning engine won't start and you find that you have to uninstall the AV program in Safe Mode and re-install it.
One of the reasons why I stopped using Norton Anti Virus some years ago.
This hasn't happened so far when using AVG.
