Author Topic: Can't get into safe mode  (Read 1459 times)
« on: April 10, 2006, 13:10 »
I am still having problems getting into safe mode.  When I hit F8, I get the boot options, select Safe Mode, and the list of drivers runs through, then stops, and after about 5 minutes, the computer automatically reboots back into normal Windows.
I'm cautious of using the SAFEBOOT option in Boot.ini, in case I can't then get back into normal Windows.  Any ideas?
« Reply #1 on: April 10, 2006, 13:12 »
Have you tried just switching off the power when in normal windows and then rebooting. That sometimes forces it into safe mode when it restarts.
« Reply #2 on: April 10, 2006, 13:14 »
Is that a good idea?  I don't want to totally screw up Windows... :|
« Reply #3 on: April 10, 2006, 13:22 »
Shouldnt do any harm Simon.
It will probably run scadisk or chkdisk, I can never remember which.
Then send a message saying that windows has recovered from a serious error.
You can always do a system restore if anything strange happens, which I have never known it cause with XP  :)
« Reply #4 on: April 10, 2006, 13:26 »
I don't trust System Restore, as it never seems to work when I need it to, but it seems I may not need to now.
« Reply #5 on: April 10, 2006, 13:28 »
You could always image your C drive as a precaution then it would be an easy matter to use that as a guaranteed system restore point  :)
« Reply #6 on: April 10, 2006, 13:34 »
Yes....  I know I should, but it sounds a bit too much like hard work.  :blush2:  I'll be formatting and reinstalling Windows at some point, so perhaps then I'll partition my drive, and do things properly.  ;)
