Author Topic: M$ office alternatives.  (Read 2318 times)
« on: April 15, 2006, 17:41 »
Ok you might be happy and think M$ office is good but do you like the attached price? I don't. You probably know I'm a big open source person but I really do like M$ office, not that I would use it to write reports in or anything (I use a typesetting program could LaTex). Anyway, I do like M$ office. I think it is great but it is expensive so how about a cheap (i.e. free alternative and no I don't mean BiTTorrent! :-) ). Here are a few contenders (I am to add to this in time):
AbiWord  - http://www.abisource.com/
              - nice and small, only (currently) 5.1 mb
              - you can get the source code!!!
              - works on the mac, linux and windows!!
OpenOffice - http://www.openoffice.org/
                 - the biggest and best contender to microsft's rein
                 - it is good and powerful, lots of useful M$office like features
                 - smaller than M$office, and free
                 - not as small as ability office.
                 - linux, mac and windows versions
ThinkFree Online - http://online.thinkfree.com/index.jsp
                         - doesn't need installing
                         - online only
                         - odd but only needs net connection and java...
« Reply #1 on: April 15, 2006, 18:46 »
I've been using Open Office for several months now and prefer it to my antiquated version of MS Office 97.  The maths module can be useful at times.
Gill
« Reply #2 on: April 15, 2006, 18:57 »
btw, did you know that there is a similar maths program within M$ just it isnt normally installed by default (equation edit btw).
What version of open office are you using??
« Reply #3 on: April 15, 2006, 20:15 »
I didn't know about the maths program within MS Office - how strange that it should be obscured.  I'm using v2.00 of Open Office.
« Reply #4 on: April 15, 2006, 20:17 »
thats a nice version, if you wasnt using that I would have suggested upgrading since there have been some great developments.
You should be able to use equation edit in M$ Office if you insert object... and choose it. It should be installed, but you never know it might not be.
« Reply #5 on: April 15, 2006, 22:32 »
If you are a student or work in education, you can get Sun Star Office free of charge.  I recently downloaded it and have it installed on a spare PC that I use to mess about with.
http://www.sun.com/software/star/staroffice/education.jsp
« Reply #6 on: April 15, 2006, 22:50 »
yep good one there dave, not quite sure how i forgot to put that in my original list,  though it is basically open office these days.
