Author Topic: Wireless Network Security  (Read 1170 times)
Offline kevinho
« on: April 15, 2006, 21:37 »
Ok have finally gone wirless but unfortunately for the moment just have the one desktop pc on the "network"  :)   My question is about security which should i choose?
64 bit WEP, 128 bit WEP, WPA (with radius server) or WPA PSK (No server)?
And would there be any advantage in using McAfee Wireless home network security ?
I intend to be running 3 pc's on the network 2 desktops and a laptop.
Its a wireless "G" modem/router and kit.
« Reply #1 on: April 15, 2006, 23:50 »
I have run mine with 64 bit WEP for the last couple of years without any problems.
Its bad enough having a 10 hexadecimal code to type in, I think with 128 bit you end up with a 25 unit code  :shock:
Offline kevinho
« Reply #2 on: April 16, 2006, 10:24 »
Thanks Sandra.
Would there be any advantage in installing McAfee's Wireless home network security?
« Reply #3 on: April 16, 2006, 13:32 »
I havent used it myself so I dont really know on that one.
As long as WEP is enabled I think that you should be ok with that alone.
I suppose it depends on where you live as well.
Wi Fi has a limited range so if you are in the middle of a field then you probably wouldnt need WEP at all whereas if youre in a block of flats then lots of people would be within range of your router.
