This may not help, but it's worth noting that disabling firewalls often doesn't actually switch them off, or if it does, they leave the current security level maintained. This is so that malicious programs can't disable your firewall. The only way is to find the option which makes the firewall start with Windows, disable it, and reboot, so the firewall doesn't start in the first place. It's not adviseable to use your internet connection without an active firewall, but it's OK to set up something like this.
However, you may just need to configure ZA to allow your network IP, so it might be worth having a tinker in ZA's settings first.
