Hiya!
About 6 weeks ago my Dell laptop fell off the couch, I can't remember if it was on at the time, I don't think so though. Actually, I think it might have hibernated itself because the battery was low.
Anyway a couple of days after that, I tried to turn it on but it wouldn't. I plugged in the charger but the battery/charging light on the front didn't go on. I thought maybe the charger was broken, but it wasn't until today that I actually got round to testing this. I borrowed someone elses charger, which is also Dell. Again, the charging light didn't come on.
At this point I realised there must be something wrong with my laptop so after discovering I'd lost my instruction booklet I decided to have a look inside to see if anything was damaged. I uncrewed a little compartment on the underside but I dont know what it was that was inside, it looked like ram. That was it. Except for a tiny plastic slider, with a little arrow on it. On the outer casing it had a wee symbol where the slider was, which was like a circle inside a circle. Out of curiousity I tried to slide it but it didnt go far and pinged right back. I don't know what it was, probably not even relevent but I thought i'd mention it anyway!
I discovered the huge thing on the side of the laptop which I thought was some sort of expension bay turned out to be the battery as I figured out how to remove it. It looked fine, so I just slid it back in and it clicked into place.
I tried plugging in the charger again and both the power light and battery/charging light started flashing furiously. It did it for about 1 minute and then they both went out again, so I unplugged it and tried again. This time they flashed for about 10 seconds and went out. The next couple of times I tried, the flashing time got less and less and now when I plug in the charger it flashes for about 1 or 2 seconds and then goes out.
I've never seen either light flashing like this before and I'm really worried now! Is there something wrong with my battery?
My laptop is a Dell Latitude 100L, 256mb RAM, pentium 4 2.4 ghz (i think)
Please help me!! I hope this is fixable, and if it is, not too dear!
Thanks soo much.
Linz xx
